Symfonium provides its own binary repositories for F-Droid-compatible clients, as well as APKs for manual installation. These repositories are separate from F-Droid’s default repository, so you must add the appropriate Symfonium repository before the app appears in your client.
Choose the repository for your device
Section titled “Choose the repository for your device”Open the repository hub and choose the repository that matches your device. Use the phone repository for phones and tablets, or the Android TV repository for Android TV devices.
The hub provides direct add links, QR codes, repository fingerprints, and browsable archives for every feed.
Beta repositories
Section titled “Beta repositories”Beta repositories provide prerelease builds for testing and may be less stable than production releases. Choose either the production or beta repository for your device. Do not add both.
Add the repository and install Symfonium
Section titled “Add the repository and install Symfonium”- Install or open an F-Droid-compatible client on the target device, such as F-Droid, Droid-ify, or Neo Store.
- Open the repository hub from the link above, choose the production repository for your device, then select Add in F-Droid / Droid-ify. Alternatively, display the hub on another screen and scan the QR code for the correct feed.
- Review the repository name, URL, and fingerprint shown by your client, then add or enable the repository.
- Refresh the repository list if needed, find Symfonium, and install or update it.
If the direct add link does not open your client, copy the repository URL displayed on the selected repository page and add it from the client’s repository settings. The interface varies by client. See F-Droid’s guide to adding a repository for the F-Droid workflow.
Download and install the APK manually
Section titled “Download and install the APK manually”You can install Symfonium without an F-Droid-compatible client:
- Open the repository hub and select the production or beta repository for your device.
- Select Latest APK under Symfonium to download the current package from that repository.
- Open the downloaded APK and follow Android’s installation prompts. Android may ask you to allow APK installations from the browser or file manager you used to open it.
A manual installation does not check the repository for future updates. To update Symfonium, return to the same repository, download its new Latest APK, and install it over your current version.
Before opening an issue
Section titled “Before opening an issue”Update Symfonium to the latest version available in the repository you use, including when you install its APK manually. Reproduce the problem on that version before opening an issue so that you do not report a problem that has already been fixed.
Downgrades and backups
Section titled “Downgrades and backups”The archives on the repository hub let you browse older releases. Their availability does not make downgrading safe or supported. See Settings - Backup & restore before making changes that could remove app data.
