Most Google Play licensing problems fall into one of two groups: a payment did not complete, or a completed purchase is not being recognized.
Ko-fi and PayPro license requests are handled separately. Start with the section that matches your situation.
Start with your situation
Section titled “Start with your situation”- If Google Play does not complete the payment or no completed order exists, follow A Google Play purchase cannot be completed.
- If the order completed but Symfonium is still locked, follow A completed Google Play purchase is not recognized.
- If your Ko-fi license is not recognized or you need to transfer it to another device, follow Ko-fi licenses.
- If you purchased a Web license through PayPro, follow Web licenses.
License basics
Section titled “License basics”Where can I find my Google Play order number?
Section titled “Where can I find my Google Play order number?”A completed Google Play purchase normally uses the GPA. prefix for its order number. You can find it in your Google Play order history or Google Payments. Make sure you are signed in with the account used for the purchase.
Can I use my Google Play license on multiple devices?
Section titled “Can I use my Google Play license on multiple devices?”Yes. The license is not limited to one device and does not need to be moved between devices. You can use it on as many compatible Android devices as needed, including several at the same time. On every device, Symfonium must be installed through the same Google account that purchased the license. If the purchase is recognized on one device but not another, follow The purchase is not recognized on another device.
Can I transfer a Google Play license to another Google account?
Section titled “Can I transfer a Google Play license to another Google account?”No. Google Play does not allow purchases to be transferred between accounts. If several Google accounts are present on the device, Symfonium must be installed through the account that purchased the unlocker.
Can I share the license through Google Play Family Library?
Section titled “Can I share the license through Google Play Family Library?”No. The Symfonium unlocker is an in-app purchase, and Google Play does not allow in-app purchases to be shared through Family Library. The license can be restored on compatible devices using the purchasing account, but it cannot be shared with another account.
Will a Google Play license work without Google Play?
Section titled “Will a Google Play license work without Google Play?”No. Google Play must be available and able to validate the purchasing account.
Can I move a license between Google Play, Ko-fi, and PayPro?
Section titled “Can I move a license between Google Play, Ko-fi, and PayPro?”No. They are separate license systems. Each system has its own process for moving or restoring a license.
How do I request a Google Play refund?
Section titled “How do I request a Google Play refund?”Start by requesting the refund from Google Play. If Google Play does not handle the request, contact Symfonium support with the Google Play order number, purchase date, amount paid, and reason for the request. See Get help and share feedback for more details.
Section titled “A Google Play purchase cannot be completed”Google Play processes the payment. Symfonium does not receive your card details and cannot resolve a declined or pending transaction. Work through these checks in order:
- Confirm that the Play Store is using the Google account and Play country you intend to use for the purchase.
- If your Android version provides App data sync under Android Settings > Accounts > Google, ensure it is enabled for the purchasing account.
- Check whether an order was created in your Google Play order history. A pending or cancelled transaction does not provide a license that Symfonium can restore.
- Follow Google’s payment troubleshooting. Complete any confirmation requested by your bank, or try another payment method available in your country, such as PayPal where supported.
- Check the internet connection and temporarily pause any VPN, firewall, ad blocker, or DNS filter that could interfere with Google Play.
- Enable automatic date, time, and time zone in Android settings, then restart the device. If the values were already correct but validation still fails, briefly set an obviously incorrect time, then immediately restore the correct automatic date, time, and time zone before restarting.
- Update the Google Play Store from Play Store > Profile > Settings > About > Update Play Store, then retry the purchase.
- If the Play Store purchase dialog fails during biometric confirmation, toggle the Play Store Biometric verification setting, return it to its original state, then retry. See Google’s purchase verification guidance.
Some devices include a vendor-installed or uncertified version of Google Play that cannot use current Google billing services reliably. Check Play Store > Profile > Settings > About > Play Protect certification. If the device is not certified, see Google’s guidance for uncertified devices.
If a vendor-installed Play Store is too old to update through the normal action above, it must be updated before current Google billing libraries can work. As a last resort, APKMirror provides Play Store packages, but it is a third-party source. Confirm that any package is compatible with the device before installing it.
Section titled “A completed Google Play purchase is not recognized”Symfonium periodically validates the license online when it is launched. The device must be able to reach Google Play and the Symfonium validation service.
- In the Play Store, select the Google account that purchased the unlocker.
- Open the Symfonium purchase page and select Restore license.
- If Symfonium remains locked, press Purchase again. This asks Google Play to return the current ownership state. If Symfonium displays Unlocker already purchased., reboot the device.
- Ensure Symfonium itself has unrestricted network access and is not blocked by Android per-app data settings, a firewall, or a security application. Then open https://genimee.com/test in a browser on the device. It must display OK. If it does not, temporarily disable any VPN, firewall, ad blocker, private DNS, or security filter and test again. Once it displays OK, return to Symfonium and retry Restore license.
- Complete every relevant Google Play check from the previous section, including App data sync when available, automatic date and time, biometric verification, the Play Store update, and Play Protect certification.
Section titled “The purchase is not recognized on another device”Google Play can take a couple of hours to sync a recent purchase to other devices. On the device where the purchase is not recognized, open the Symfonium purchase page and press Purchase again. When Symfonium displays Unlocker already purchased., reboot the device to force a refresh.
Multiple Google accounts or installation from another account
Section titled “Multiple Google accounts or installation from another account”When several Google accounts are present, Google Play may not return the purchase if Symfonium was installed through a different account. If the steps above do not restore the license:
- Create a Symfonium backup and export the backup file outside the app before uninstalling. See Backup & restore.
- Uninstall Symfonium. This removes its app data and locally stored offline content from the device.
- On a computer or another device, open Google Play on the web. Sign in with the Google account that purchased the license, then install Symfonium remotely on the device where the license is not recognized. This fix does not work from a browser or the Play Store app on the affected device.
- Open Symfonium and use Restore license.
- After the license is recognized, restore the backup exported from Symfonium if needed.
Restored Android app data
Section titled “Restored Android app data”Restoring the complete app and its internal data with an Android backup tool can restore stale license information and trigger additional verification. Before reinstalling, create a Symfonium backup and export the backup file outside the app. See Backup & restore.
Reinstall Symfonium from Google Play, then restore only a backup created and exported through Symfonium itself.
Google Play modification or purchase-emulation tools
Section titled “Google Play modification or purchase-emulation tools”Tools such as Lucky Patcher can modify Google Play billing and prevent valid purchases from being returned to Symfonium. Disable and revert all in-app purchase emulation changes. Uninstalling the tool alone may not undo changes it previously applied.
Ko-fi licenses
Section titled “Ko-fi licenses”No new Ko-fi licenses are issued. PayPro licenses have replaced them for new purchases outside Google Play.
A Ko-fi license is not recognized
Section titled “A Ko-fi license is not recognized”Symfonium needs regular internet access to validate Ko-fi licenses. If your license is not recognized, work through these checks:
- Open https://genimee.com/test in a browser on the device. It must display OK. If it does not, temporarily disable any VPN, firewall, ad blocker, private DNS, or security filter and test again. Once it displays OK, reopen Symfonium to retry license validation.
- Open About in Symfonium and check that Device ID is visible and matches the ID associated with your license. If it is different, follow Transfer a Ko-fi license below.
- If Device ID is missing, reinstall Symfonium from the Symfonium F-Droid repository. Uninstalling removes app data and locally stored offline content. If you can still access Backup & restore, create and export a Symfonium backup before uninstalling. If the app is locked and you cannot create a backup, you can still reinstall, but you will need an existing exported backup to restore your previous configuration. Ensure Symfonium has internet access on its first start after reinstalling, then check About again and confirm that Device ID matches your license.
Section titled “Transfer a Ko-fi license”To transfer a Ko-fi license to another device, send a private message on Ko-fi with the previous device ID and the new device ID. You can find the device ID on the Purchase and About pages in Symfonium.
Web licenses
Section titled “Web licenses”PayPro licenses are the replacement for Ko-fi licenses.
A PayPro license is not recognized
Section titled “A PayPro license is not recognized”Symfonium needs regular internet access to validate PayPro licenses. If your license is not recognized, work through these checks:
- Open About in Symfonium and check that Device ID is visible and matches the ID associated with your license. If it is different, follow Transfer a PayPro license below.
Section titled “Transfer a PayPro license”To transfer a PayPro license to another device, follow the license-transfer procedure provided in the email you receive after purchase. Keep that email and its purchase information private.
Contact support
Section titled “Contact support”Declined, pending, or cancelled Google Play payments must be resolved through Google Play. Refund requests follow the refund process described above and do not require diagnostic logs.
Include the purchase details for your license type:
- Google Play: the
GPA.order number and purchase date - Ko-fi: the Device ID shown in About and your Ko-fi receipt
- PayPro: the Device ID shown in About and your PayPro receipt
For every technical license activation or validation issue, also include all of the following:
- The exact error message and the approximate time it occurred
- The result of every relevant troubleshooting step on this page
- Your device model, Android version, and Symfonium version
- Fresh logs: enable Debug mode, reproduce the license issue, disable Debug mode, then share the logs immediately
- The exact description used when sharing the logs
Support cannot investigate the issue without the purchase details for your license type and every diagnostic item above.
Once everything is ready, open the root Settings page in Symfonium, select Contact support, and choose the email option. Send the message from the email application opened by Symfonium and include the purchase details for your license type and all the diagnostic information above. Do not use the public forum for license issues. Email keeps receipts, device IDs, order information, and other private details out of a public topic.
Never include card details or account passwords in the email.
